  • 1 Reply
  • 413 Views
DWGVMAX
Pro2 six camera set up. Five of the units are rock solid. One is a pain. So two of the cameras are side by side. One on each side of a support beam. This helps with the question is it out of range. The other camera works fine. I have even moved it. Still the same. Remove and install battery and all is good for a little while.  My question has anyone else had a camera that just will not stay online? I am a damn good trouble shooter and have been through the gambit. But am also open minded to new tricks?
Have you just swapped the 2 cameras around? That would help figure out if it's the camera or location (the beam may be absorbing signal).
  • 1 Reply
  • 414 Views
