2 Arlo Systems for a different location. Can I use the app to monitor both at the same time?
I just purchased a second system for a different location. Can I use the app to monitor both at the same time?
Yes. Depending on what subscription you may have, all cameras will show up together. If using the free plan, only 5 cameras total can be used, regardless of location. If you need more than 5, set the new system up using a second account with a second email address. Then use Settings, Grant Access from the second account to the first account's email address so all cameras are seen together.
