180 days recording on Arlo Pro 2
I used to be able to change the settings and keep recordings of up to 180 days from the default 30 days. Is it still available? If yes, where do I change the settings?
I don't think so. I've been using Arlo for years, and never saw that option. You can get 60 days if you are in Europe and are willing to pay for Secure Plus.
In any case it's not available now. You can add local storage to your hub - that would give you more than 30 days. But you'd need to eject the storage and connect it to a PC for viewing.
