- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Performance-Tips-QA-2021-02
- Will you ever allow a solution that Arlo Ultra cam...
Will you ever allow a solution that Arlo Ultra cameras can be connected directly to a home network?
- Mark Question as New
- Mark Question as Read
The current Arlo Hub has extremely limited range, making it impossible to get proper coverage on my home. As a result, I cannot use my ARlo Ultra cameras where I want them, and have resorted to adding ArloQ cameras instead for those areas. This limitation is preventing me from buying more Arlo Ultra cameras as I don't want to keep adding hubs that won't even cover 20% of the area that my home mesh network can cover.
Arlo Ultra is designed to sync only with a compatible base station/SmartHub. They will not sync to a home router.
With the Arlo Pro 4 and Essential camera series, we have started implementing AP mode connectivity options but these hardware features are not backward compatible for Arlo Ultra.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
