Turning the spot light brightness down on my Pro 3 isn’t affecting the brightness at all
I just got the Pro 3 and although I turn the brightness on the light down in the settings, it stays at 100% with movement. However, it does work when I’m live-streaming and turn the flashlight icon down. Why won’t it work in settings for when movement is picked up?
View Entire Topic
It sounds like you may not be adjusting the brightness in the right area. Take a look here: https://kb.arlo.com/000062172/How-does-the-spotlight-on-my-Arlo-camera-work
