- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Performance-Tips-QA-2021-02
- My camera is showing pink instead of green... how ...
My camera is showing pink instead of green... how do I fix this?
Options
- Mark Question as New
- Mark Question as Read
If you're experiencing odd behavior with image color, first try removing and reinserting the battery in your camera (if applicable). If you're still experiencing the same behavior, try removing the camera from settings and resync as if it were a new device. If that does not resolve the issue, please reach out to the support team to further investigate.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
0
Likes
