- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Performance-Tips-QA-2021-02
- Arlo Pro 2 missing important part of recordings.
- Mark Question as New
- Mark Question as Read
Hi James C. thanks for you response to my question about Arlo Pro 2 missing important part of recordings. I wasn't able to respond to your answer. The parts of recordings that are missing are when there was motion in the middle of the camera's view. A couple of times, there has been a recording immediately after the missing chunk, so the motion was all within the active area. And it wan't a 300 second limit either. Also, setting the camera to record for a fixed duration is not an option for where I have it set up. I just want it to record when there is motion and it currently doesn't always do that. Any other ideas?
It may take more in-depth discussion and more information about your specific environment and setup to better understand the issue you're experiencing.
I encourage you to make a post about this issue in the Arlo Pro 2 boards here on the community or reach out the Arlo Support Team to further investigate.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
