- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Performance-Tips-QA-2021-02
- Arlo Pro 2 missing important part of recordings.
- Mark Question as New
- Mark Question as Read
Hi James C. thanks for you response to my question about Arlo Pro 2 missing important part of recordings. I wasn't able to respond to your answer. The parts of recordings that are missing are when there was motion in the middle of the camera's view. A couple of times, there has been a recording immediately after the missing chunk, so the motion was all within the active area. And it wan't a 300 second limit either. Also, setting the camera to record for a fixed duration is not an option for where I have it set up. I just want it to record when there is motion and it currently doesn't always do that. Any other ideas?
Accepted Solutions (0)
Answers (1)
Answers (1)
It may take more in-depth discussion and more information about your specific environment and setup to better understand the issue you're experiencing.
I encourage you to make a post about this issue in the Arlo Pro 2 boards here on the community or reach out the Arlo Support Team to further investigate.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
