Why does the camera pick up on flags waving even when filtering is enabled for only persons?
I am still in my Trial period.  I understood that the above feature was available even now.
Accepted Solutions (0)
Answers (1)
Answers (1)
It's important to note that toggling off Arlo Smart Alerts will not reduce the number of recordings you see in the library, this only suppresses push notifications for alerts that have that tag. You may need to adjust sensitivity or camera placement to alleviate this issue if you are experiencing too many motion triggered events.
For more information on adjusting camera sensitivity, see here: https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
