- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Mobile-App-Q-A-2021-04
- My Arlo does not works in the Arizona summer heat ...
My Arlo does not works in the Arizona summer heat of 120 plus degrees what can I do?
- Mark Question as New
- Mark Question as Read
I have 5 Arlo Pro 2 with one base station in the Arizona desert, I the winter time is all good but summer time when is sometimes above 120 degrees and the cameras are outside in direct sunlight, the arlo goes off line and then stops communicating with the Internet, I have a Verizon Jetpack (wifi) connected to a router by wifi then the router connect to the Arlo base station by ethernet cable.
so when is too hot in the summer and it goes off line I need to disconnect the power cable from Arlo base station and then plug the power cable again to reboot and the Arlo base station reconnect to Internet automatically
the problem is I need to drive 60 miles to do this reboot, we use the Arlo for our security system in a storage yard
Below is one of the cameras info
Firmware: 1.125.16.0_36_49c31dd
Hardware: H5
Serial #: A0B19270A09CC
thank you
Accepted Solutions (0)
Answers (1)
Answers (1)
Arlo Pro 2 cameras have a maximum temperature threshold 104°F. The cameras will not operate beyond that and will cease functionality to prevent damage to the hardware.
For more information on operating temperatures, take a look here: https://kb.arlo.com/1705/Are-Arlo-cameras-weatherproof
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
