- English
- Services
- Arlo Home Security System
- Re: direct storage access not working with Verisur...
is the issue fixed?
I have been waiting for almost 2 years for arlo to fix it…
Is it still only way to create 2 account to link with device that not cover by verisure to get back the direct storage access view?
you can see below capture, even I updated to the newest version…there is still no option for local drive view.
HI @shochan
Please reach out to support via the following link: https://www.arlo.com/en_gb/support
Support will have More information regarding this topic.
What model base do you own? Look for a VMBxxxx label on it.
Thanks for reply, I’m using VM4540
I've been using the "Feed" interface for a couple of years now, so my own screens don't match yours.
But I think you should be seeing a "Direct Storage Access" option on that screen.
I'm tagging the mods - @BrookeN , @JamesC , @ShayneS - to see if they can help.
The Direct Storage Access button is never appear in my Arlo app since day 1.
I have been told that it’s the bug if we use Verisure security plan…
for my case, Verisure provide me a arlo doorbell, and I bought my own base and 2 cam…
but all of the devices are linked to same account…
only the doorbell is under arlo subscription provided by Verisure…
the video capture from 2 cam I bought separately is stored in the smart hub with SD card, suppose I can view the record in arlo app… but it doesn’t…I can only check the record from the doorbell, if I need to check the record from 2 cam, I need to take out the SD card from the hub and check in my computer…
there is no choice for me in the library page to check the footage from the smart hub…
Interesting, since that is not an issue I've seen posted here before. I tagged the mods in order to get clarification on that.
You could potentially create a new account for the equipment you purchased, and then share the doorbell with that account using the "Friend" feature.
Then you should be able to access local storage using that new account. Configuring the doorbell would require using the current account, but you should be able to see recordings, etc without doing that.
HI @shochan
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
