- English
- Services
- Arlo Home Security System
- Re: Temperatures only showing in Celsius, not Fahr...
Hello - the sensors for my security system only show temperatures in Celsius in the iOS app. I can’t get them to read out in Fahrenheit.
I’ve tried talking to two different support folks and they’ve not resolved the problem. They keep linking me to the same knowledge base article, which is incorrect: https://kb.arlo.com/000062899/How-do-I-change-the-displayed-temperature-to-Celsius-or-Fahrenheit-on-...
I say incorrect, because that article tells you to go to App Settings. However, the App Settings only show App Theme settings - not temperature unit settings.
I did find temperature unit settings, but it’s under the Location Settings. When I go there the Fahrenheit option is already selected. Even if I change it to Celsius, then back to Fahrenheit, nothing changes. I’ve restarted the base station, no change.
Please help! Thanks.
Can I not upload screenshots? That’d be hugely helpful if I could…I can share a screenshot showing the temp in Celsius.
You should be able too (not sure if that ability is linked to a number of posts).
Do you see a camera icon next to the smilely face in the toolbar above the posting box? The format need to be either jpg or png.
There is also a file attach underneath the posting box - that is also limited to jpg and png images.
I do now! Yes, perhaps that wasn’t available before as it was my first post.
Here’s a screenshot from the app - my expectation is that this little 10 should instead be showing in Fahrenheit (50 degrees).
If you add a sensor card to your dashboard to display temperature, does it display in Fahrenheit?
Oh, good idea. Yes, it does!
@JamesC Do you work for Arlo? Are you able to file a bug to get this fixed?
tysongach,
Yes. I've passed this along to the dev team.
Wonderful - thank you so much! I was going in circles via support chat and wasn’t getting anywhere. Seems like this community forum is a much better place to have conversation and find resolution!
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
