When using the keypad sensor hub to change mode to Arm home, the system immediately changes state unlike when changing mode to Arm Away where there is a delay allowing person to leave before changing state.
Is there a way to insert this delay for changing mode to Arm Home also. This is useful when leaving the premises and there are still other people in the house.
ajfjavi,
You can add a delay for Arming or Disarming your system within your Arlo location settings. Take a look here for instructions on how this is done: https://kb.arlo.com/000062780/How-do-I-configure-an-entry-or-exit-delay-for-my-Arlo-Home-Security-Sy...
You can't change the delay (or lack thereof) but you could use the Automations to set up geofencing. Of course, that means the other folks would need the Arlo app on their phones with GF set up.
ajfjavi,
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
