Security keypad - can not select network
  • 2775 Views
Lrep
Hello.  I am trying to set up a new security keypad.  I am using an iPhone 15 Pro and am connected to a 2.4 network with cellular data turned off.  Local network access is enabled.  During the setup process, after I click "Continue" with the check mark flashing on the keypad, I get a pop up window that says "Arlo Secure" Wants to Join Wi-Fi Network "Arlo_9226" with the choices "Cancel" and "Join".  When I select "Join", after a few seconds the Wi-Fi icon of my phone goes away and I get another pop up with the error message "Unable to join Arlo_9226" with some other text about checking to make sure the device is turned on, etc.  At this point, the Wi-Fi icon turns back on and I am connected to my home network.  I never get to the connection step where I am asked to chose a network.  I am pretty sure that "Arlo_9226" is my keypad, because that network goes away from the list of networks on my phone when I unplug the keypad.
I have tried troubleshooting on my own, and have spent an hour with Arlo customer support, but I had to disconnect because I had other things to do.
Here are the things I/we have tried, one at a time and in many combinations:
Factory reset the keypad
Verified that my network is 2.4
Disconnected every other Arlo device I have on the network
Deleted and reinstalled the Arlo app
Restarted my phone
Tried running the installation from my iPad
I have not tried throwing the keypad against my wall, but I have wanted to.
I am outside the 30 day return window or I would.  However, I really do want this to work, as I have several other Arlo products.  Thanks for any suggestions.
BrookeN
Please try the following steps to see if you are able to get the keypad set up on the account:
https://kb.arlo.com/000062804/My-Arlo-Keypad-Sensor-Hub-will-not-connect-to-my-Wi-Fi-network-what-do...
BrookeN
Is there another device in the house you can try setting the keypad up with by any chance?
tdgee
hey there - any chance you were able to resolve this? we are running into the same issues....
BrookeN
