Hello. I am trying to set up a new security keypad. I am using an iPhone 15 Pro and am connected to a 2.4 network with cellular data turned off. Local network access is enabled. During the setup process, after I click "Continue" with the check mark flashing on the keypad, I get a pop up window that says "Arlo Secure" Wants to Join Wi-Fi Network "Arlo_9226" with the choices "Cancel" and "Join". When I select "Join", after a few seconds the Wi-Fi icon of my phone goes away and I get another pop up with the error message "Unable to join Arlo_9226" with some other text about checking to make sure the device is turned on, etc. At this point, the Wi-Fi icon turns back on and I am connected to my home network. I never get to the connection step where I am asked to chose a network. I am pretty sure that "Arlo_9226" is my keypad, because that network goes away from the list of networks on my phone when I unplug the keypad.
I have tried troubleshooting on my own, and have spent an hour with Arlo customer support, but I had to disconnect because I had other things to do.
Here are the things I/we have tried, one at a time and in many combinations:
Factory reset the keypad
Verified that my network is 2.4
Disconnected every other Arlo device I have on the network
Deleted and reinstalled the Arlo app
Restarted my phone
Tried running the installation from my iPad
I have not tried throwing the keypad against my wall, but I have wanted to.
I am outside the 30 day return window or I would. However, I really do want this to work, as I have several other Arlo products. Thanks for any suggestions.
Please try the following steps to see if you are able to get the keypad set up on the account:
https://kb.arlo.com/000062804/My-Arlo-Keypad-Sensor-Hub-will-not-connect-to-my-Wi-Fi-network-what-do...
Is there another device in the house you can try setting the keypad up with by any chance?
hey there - any chance you were able to resolve this? we are running into the same issues....
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
