  • 1 Reply
  • 738 Views
Tweetiebirdbell
 How do I fix this. Everything seems to be working otherwise.
Start by removing power to the hub, wait several seconds and then plug it back in. This assumes you don't have the battery backup - if you do, you'll need to remove that from the hub, too. If still the same thing, reboot the phone and reinstall the app as well as using a computer browser pointed to my.arlo.com to check.
