Arlo Pro VMB4000
I have upgraded to an AT&T home internet wireless system. There is not a ethernet port to plug my Arlo Pro VMB4000 into. There are two ports, one labeled 1GB and the other 10GB. Will one of these work or is there something else I need to do?
These are both ethernet ports. Use the 1 GB one - some 10 GB ports don't support the 100 MB/s ethernet used by the VMB4000.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
