Buonasera, non riesco ad accedere alle registrazioni in locale su SD dal mio IPhone. Quando provo ad accedere alla libreria il sistema mi dice che i filmati non sono disponibili e devo verificare le connessioni di rete. Per favore potete aiutarmi a risolvere il problema? L’impianto è composta da tre videocamere Arlo pro3 ed ho speso parecchio. Vorrei poter utilizzare le funzioni per le quali ha pagato. Grazie
Does this happen when you are home, with the phone connected to your home wifi?
If you use a VPN on your phone, try turning it off.
Hi Stephen, first of all thanks for your promply reply. Confirm that I have the problem also when I connect with my Wi-Fi home. My iphone haven’t VPN actived. If use a Samsung Phone I can see the records in Arlo Hub without problems. I don’t undertand which is the problem. Thanks regards Domenico
Check that the iPhone app is up to date.
App updated but the problem is still there.
Is the app allowed to access local data? Go into the apple settings and scroll down to the Arlo app to check.
Yes, the app si allowed… I also tryed to turn of the Arlo Hub. Still nothing
Since this works ok with the Android app, it seems unlikely to have anything to do with the hub.
That said, this is a puzzle, and I don't have any suggestions for next steps.
Hi Stephen, I understand…, sincerly don’t know what I’ll do to solve this problem. Thanks a lot for your suggestions. Ciao
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
