New App Upgrade
Stay way from the new app upgrade.
first of all it removes all your preset security settings and you have to reprogram everything again.
second the programming makes no sense. I have put the cameras on standby but they still activate.
it is a mess!
Arlo need to do something about this new app ASAP.
This is the worst i have ever navigated through, an absolute horrible mess.
HI @halfmoon83
Can you direct message me with more detail regarding your desired schedule and which cameras you would like Active/disabled including rules and I can take a look.
Hi Shayne
Thanks for reaching out. I eventually managed to work it out and I think it is now correctly activated.
The programming is not very intuitive and, the way I read it, "Standby" and "Home Armed" modes are exactly the same thing. ... you can set some cameras on standby and others to be armed... in both modes.
What I do like is the "away Armed" which automatically sets all cameras to armed.
@halfmoon83 Thanks for the update.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
