Arlo Subs?
i really dont get what im supposed to do for subs. i have a floodlight and a doorbell so 2 devices but yet when i try and pick a sub it doesnt make sense
the single plan allows me to have 1 device and if i select both it makes me pay £8.98. however if i select the multi plan fore more than 1, it says to drag a camera to be included but i see no devices?? i just want 1 sub ?
You may want to reboot the phone and reinstall the app but the issue may be due to your use of the old UI that uses Library to view recordings. That UI has the feature your screenshot shows while the new UI that uses Feed does not. You may need to migrate to the new UI by choosing to install a Pro 5 even though you don't have one. The first step is to migrate the account after which you can just back out of the bogus install. The new UI is significantly different and custom modes don't transfer so this may not be the best solution at the moment.
this is the website version im running on firefox, so its not even on my phone lol
i got the reminder email , opened it up and then i was presented with 3 plans and this is where im at.
I tried the website and see essentially the same thing. Can you use a phone to do this? I'm not sure why you can't with the website but...
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
