- English
- Services
- Arlo Home Security System
- Smoke Detector in Standby Mode doesn't trigger eme...
Smoke Detector in Standby Mode doesn't trigger emergency response
I have Arlo security system with the trial for safe and secure plan.
When a smoke detector alarm is detected by the base station or by a sensor, is it possible to alert emergency responders?
The "rules" for standby mode when a smoke detector is detected only show the option for a notification.
It looks like absolutely nothing can trigger an "emergency" in standby mode.
I tested this and set off a smoke detector in standby mode and all I got was a notification. No emergency response.
So is it possible to have smoke detectors trigger an emergency response in standby mode?
Sadly this is a deal breaker for me If not.
Hi @bicarbon
At this time, Emergency Response Panic as an action in Standby is not supported. I will provide this info to the appropriate team for future consideration. Thank you for the feedback.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
