- English
- Services
- Arlo Home Security System
- Local events from base station VMB5000r6 not shown...
Local events from base station VMB5000r6 not shown on new iPhone17p
Hallo,
After installing my new iPhone17p I can't see the local events in the Arlo secure app, the events are stored on my local base station VMB5000r6. In the Arlo secure app -> Feed -> Local - under local it see No Events. My iPhone is on the same wifi network as the basestation. The events is still showing on the old iPhone15p. I have restartet the base station and the iPhone17p but it does not help. I am logged on with the same user on both iPhones.
Appreciate any help except going back to old iPhone 🙂
Can you please make sure that the cameras have the correct routines are set up on the iPhone 17. That the cameras are set to record.
@BrookeN wrote:Can you please make sure that the cameras have the correct routines are set up on the iPhone 17. That the cameras are set to record.
apparently everything has been set up properly. Since "The events is still showing on the old iPhone15p".
@AG400 (assuming "events" mean local recordings),
- what login account are you using on the iPhone 17? Same or different one from the iPhone 15p?
- on iPhone 17, can you see the events/local recordings from Devices >> your Smarthub >> storage settings ?
Alex
Yes the new iPhone17 has the routines from the old phone, the routines have not change and are visible on the new iPhone17
Hallo,
Yes event = local recordings.
Login: using the same login as on the iphone 15
On iPhone 17 - Arlo app: Devices -> select Base station -> device settings -> storage settings -> local storage settings (settings are the same on the 2 iphones)
On the old iphone 15 under storage settings I can see all the recordings by date and time but on the iphone 17 they are not shown.
Try to reset the basestation and add it back to the iPhone 17, you will need to add the cameras back on as well.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
