Keypad
My keypad CONSTANTLY goes offline for a couple minutes, then comes back online by itself without my doing anything. It does it basically all day and all night. It's very annoying because I get an audible alert on my phone all night long while sleeping and I never know if it's a camera detecting motion outside or the keypad.....
Move the keypad closer to your router for testing. It may be an issue with signal strength/quality. If that works better, check the original location for other nearby wireless devices that use the 2.4GHz band.
It's literally about 12 feet from my router. Signal strength is not the issue. I've read of this issue online and it appears that this is a common problem. Lately it's been better, but it seems to vary from day to day. When I reached out here it was happening literally every 10 minutes or so, but now it seems it's back to only a few times a day....... ?
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
