How to set exit/entry delay for home security system
  • 1 Reply
  • 3464 Views
Dan7h3man
I just got the new home security system set up and wanted to change the entry and exit delay times. There is a support document (How do I configure an entry or exit delay for my Arlo Home Security System?) but it is incorrect. Steps 1-3 are correct, then instead of going to emergency response go to panic. Then click on arm away or arm home and the settings are in there. Below are how the steps should read
  1. Launch the Arlo Secure App or log into your account at my.arlo.com.
  2. Tap the person icon (in-app) or click Settings on my.arlo.com
  3. Select your Location.
  4. Tap or click Panic.
  5. Tap or click Arm Away or Arm Home.
  6. Tap or click Exit Delay.
  7. Select 0 sec, 30 sec, 1 min, 1 min 30 sec, 2 min, or 3 min.
  8. Tap or click Entry Delay for each device.
  9. Select 0 sec, 30 sec, 1 min, 1 min 30 sec, 2 min, or 3 min.
Dan7h3man,
Thank you for the feedback! I will pass this along to the knowledge base team for correction.
