- English
- Services
- Arlo Home Security System
- Re: How to set exit/entry delay for home security ...
I just got the new home security system set up and wanted to change the entry and exit delay times. There is a support document (How do I configure an entry or exit delay for my Arlo Home Security System?) but it is incorrect. Steps 1-3 are correct, then instead of going to emergency response go to panic. Then click on arm away or arm home and the settings are in there. Below are how the steps should read
- Launch the Arlo Secure App or log into your account at my.arlo.com.
- Tap the person icon (in-app) or click Settings on my.arlo.com
- Select your Location.
- Tap or click Panic.
- Tap or click Arm Away or Arm Home.
- Tap or click Exit Delay.
- Select 0 sec, 30 sec, 1 min, 1 min 30 sec, 2 min, or 3 min.
- Tap or click Entry Delay for each device.
Dan7h3man,
Thank you for the feedback! I will pass this along to the knowledge base team for correction.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
