How can i speak to a live person
Hello im trying to add two new cameras to my acct and am unable to do without speaking to a live person (I had brain surgery and cannot follow written directions well)
@Hippychild00 I can have someone reach out to you and help with setting up the cameras. Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
I’m Steve please call me at 11 am on Wednesday October 15th thank you I appreciate it
@JDX534awps can you tell me more what you are needing from support. That way I know if us in the community can help and if we cannot I can reach out to support to contact you.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
