Does the Arlo Home Security System work like a traditional home security alarm?
  • 1 Reply
  • 463 Views
Jshoe
My current system sends a signal to me or my monitoring station upon triggering a sensor. If no code is entered within 30 or so seconds, it sounds the alarm. If a code is entered,  a signal is sent back to the CO and everything is disabled. If someone attempts to break in, disconnect the phone line, tamper with it prior to the 30 seconds the CO doesn't recieve the disarm signal and dispatches. Does the Arlo Home Security Alarm do the same thing by sending a signal to the user or CO as soon as a sensor is triggered and operate in the same fashion? Thanks
ShayneS
Hi @Jshoe
Yes the Home security system operates in a similar fashion. You can find more information hereL https://kb.arlo.com/000062858/Arlo-Home-Security-System-FAQ#:~:text=The%20Arlo%20Home%20Security%20S...
