How do home security sensors work with security system?
  • 1 Reply
  • 1288 Views
  • 1 In Conversation
Jshoe
My current system sends a signal to me or my monitoring station upon triggering a sensor. If no code is entered within 30 or so seconds, it sounds the alarm. If a code is entered, a signal is sent back to the CO and everything is disabled. If someone attempts to break in, disconnect the phone line, tamper with it prior to the 30 seconds the CO doesn't recieve the disarm signal and dispatches. Does the Arlo Home Security Alarm do the same thing by sending a signal to the user or CO as soon as a sensor is triggered and operate in the same fashion? Thanks
I am reposting this because the response I got was not relevant and no reply button was available just accept as solution, which it was not.
Jshoe
I simply want to know if the server is notified as soon as a sensor is triggered like a traditional alarm and then disarmed once a code is answered. If not, anyone can just walk up and unplug the base to bypass the alarm rendering it useless.
