Is there a phone number for professional monitoring, I cannot seem to locate it
To utilize this feature, you must have an Arlo Safe & Secure Pro plan and have finished setting up Emergency Response.
When an alarm event is triggered, you will have a grace period to stop the alarm activation (entry delay). Once countdown expires, you will receive a call and SMS from the 24*7 monitoring agent, along with any other contacts nominated in Emergency Contacts list. If there is no further feedback within a timely manner, the agent will dispatch appropriate emergency response depending on the trigger type (eg. door open while armed will result in police being sent).
You can refer to the following documentation for more information on this: https://downloads.arlo.com/support/arlo-home-security-system/201-50585-02_Arlo_Home_Security_System_...
Thank you, James, I do have the Arlo Safe & Secure Pro plan and have finished setting up Emergency Response.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
