My hub daily drops cellular backup signal and there are always two(2) bar signal strength..Now it has started with no wifi.. not connected.. hub is about 12 ft from wifi router.. Any suggestions as to what’s causing this??
Not sure what you're trying to say since the hub does not have "cellular backup signal". The hub ONLY connects via the Ethernet cable to your router. You might want to try reseating the cable on both ends or even try a different router port.
@Cowhead is talking about the home security system hub, which does have a cellular backup option.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
