  • 4 Replies
  • 881 Views
NormOB
Without input
ShayneS
Are you still experiencing this symptom?
Can you provide more details regarding this symptom? also, May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
NormOB
All I've done is to reload the Arlo app on my phone.  It did not change anything.
It seems my system moves the status from either Arm Away or Arm Home to Standby at either 5:00 PM or around 11:55 PM if I rearm it after 5:00 PM.
Another problem I have is that sometimes the cameras do not detect any motion, even when it is blatantly obvious.
Verify that you are or are not using a schedule in Routines, Automations. ALso, if in Standby, by default no detections are used. Check that mode for rules (there shouldn't be any unless you put some there).
ShayneS
@NormOB
I see you have a schedule set for these exact times.
