- English
- Services
- Arlo Home Security System
- Which camera are compatible with midSW-AR1 batteri...
Which camera are compatible with midSW-AR1 batteries
I ordered batteries for my Arlo cameras- they fit a different camera and I don’t know which one ( id like to order)
Message 1 of 2
570
We need to know which cameras you have. Open the battery door and look for a label that has VMCxxxx. Alternatively, go to the settings for each camera type and look in Device Info for the Product Type.
Message 2 of 2
567
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
