Arlo Smart Hub inexplicably goes offline
I have a 4540 with 5 Arlo 2s and 1 Essentials.
System has worked great for 1½ years.
In July, hub started going offline everyday. To get it back online, I had to restart my AT&T internet gateway.
Long story short, replaced hub 2x, cat 6 3x, att gateway 1x.
Disabled AT&T's Active Armour.
Opened firewall to hub IP/port.
Escalated to backend att support. That can take 10 days for a response.
I am convinced this is a configuration issue on AT&T's end.
Is anyone else having this issue?
Thanks,
Arlo Smart Hub
Please contact support. Within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
