Arlo Smart Hub inexplicably goes offline
  • 1 Reply
  • 935 Views
Tmotofga
I have a 4540 with 5 Arlo 2s and 1 Essentials.
System has worked great for 1½ years.
In July, hub started going offline everyday. To get it back online, I had to restart my AT&T internet gateway.
Long story short, replaced hub 2x, cat 6 3x, att gateway 1x.
Disabled AT&T's Active Armour.
Opened firewall to hub IP/port.
Escalated to backend att support. That can take 10 days for a response.
I am convinced this is a configuration issue on AT&T's end.
Is anyone else having this issue?
Thanks,
BrookeN
Please contact support. Within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing.
