Arlo Automations are gone on my Android phone (Samsung S25)
  • 7 Replies
  • 581 Views
Simk1n
All of a sudden, i noticed that the Automations page on my Samsung S25 is empty.
I cannot add new automations either, i just get empty pages.
I have tried deleting buffer and app data. Uninstall and install the app.
Tried several older versions but it is the same.
I dont know exactly when this happened, but it is there on both my iPhone, my wifes iPhone and if i log on my browser on PC.
Samsung Galaxy S25
7 REPLIES 7
I'm not 100% sure this could be the problem but check to see if you have a subscription. I don't believe you need one for these features but...
Are you using the same credentials on the iPhone when you log in on the S25?
Simk1n
I have the same subscription plan when i bought the VMB4000 and PRO 2 in 2018 or so. Arlo Premier or what it's called.
I have not done anything and this just happened out of the blue.
I'm using the same login on both my iPhone and Samsung
Simk1n
I'm using the same login on both my iPhone and Samsung.
ShayneS
Hi @Simk1n
Are you still experiencing this symptom?
Simk1n
I forgot to reply back.
No i fixed it. Had to go into my iPhone and set up the automation rules again, as they had been removed somehow, probably after an update.
ShayneS
@Simk1n
Got it, thank you for the update.
