  • 4 Replies
  • 3037 Views
zippybubble21
i have a base with 2 arlo q  - my internet went out - and now that it is fixed the cameras will not sync-
i have tried unplugging the base- took the batteries out of the cameras
tried syncing via app, computer and directly to the base
have read post for hours
nothing working
Are you referring to the Pro cameras or the Qs? FOr the Pros, what are the LEDs on the base showing? Are the batteries charged? Have you tried with the AC power adapter?
zippybubble21
the arlo magnectic indoor/outdoor add on cameras that you connect to the base
zippybubble21
and yes tried having them plugged in-  they are the Go cameras
There's a specific section here for the Go cameras - this section is for the Pro 2, hence some confusion.
The Go cameras should automatically connect when cell service is restored as long as the battery is charged (loss of signal can drain the battery). You may need to remove them from Settings, My Devices and set them up as if new. Your cell provider may need to check the SIM card as well as your data plan, too.
  • 4 Replies
  • 3038 Views
