  • 4 Replies
  • 2489 Views
jockster
Hi Everyone,
For some reason, geofencing which used to work when I first installed the camera no longer works. The rules are set to away: armed, home: disarmed, but it records anyway.
Also, the various modes disappear completely from the list at times. These problems may have been happening since a firmware update if I remember correctly.
Very annoying when you have to arm and disarm manually and the options sometimes don't even appear on the screen! I'm starting to wish I'd installed a good old (reliable) CCTV camera  😞
ShayneS
What Device/Model/OS/Version of the Arlo Mobile App are you using & Are these modes disappearing on the Mobile App or the web portal?
jockster
Hi,
In answer to the person who replied to my ongoing issues regarding geofencing that doesn't work, and the disappearing modes: The model I'm talking about is the Arlo Go camera and solar panel, purchased from a Telstra outlet.
I rarely use the web portal (I assume this means access via my home computer?), as I'm often away from home I use the mobile app.
Regards  Jim.
jockster
I meant to add that the mobile app firmware is up to date: not sure what the version is, but it tells me it's the latest....
ShayneS
Hi @jockster
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
  • 4 Replies
  • 2490 Views
