Failing Arlo solar panels
Is anyone else finding the Arlo solar panel for the Arlo Go camera doesn’t last very long? We have gone through 3 panels in 18 months.
Airspread,
What behavior are you experiencing that is causing you to have to replace the panel?
It just stops charging the battery and once replaced with a new solar panel the battery charges fine again.
Airspread,
Are they showing any signs of physical damage?
If this occurs again, i'd recommend reaching out the Arlo Support team using the Arlo Secure mobile app under Settings > Support.
Modes et règles
