  • 6 Replies
  • 3601 Views
ArloGoVML4030
Anyone tried a car battery as power source? Reolink go users use this adapter and depending on use it can last for months. Arlo go is 7v right? Could it work with the right adapter?
-Arlo Go VML4030-100PES SN: 51D Location: Sweden FW: 1.096.3.1_1.8.63.0_0 .6.5.19.GC.002 -
6 REPLIES 6
ArloGoVML4030
https://www.amazon.com/Car-Voltage-Converter-Regulator-Smartphone/dp/B07RYT4KKK does the cpt converter exist as 7v also?
ArloGoVML4030
Maybe this will work with micro usb https://www.amazon.com/DROK-Converter-Step-down-Transformer-Regulator/dp/B00C66B3PM
ArloGoVML4030
arlo go require 7v right?
ShayneS
I have provided an article with required specifications here: What power adapter can I use to charge my Arlo Pro or Arlo Go batteries?
ArloGoVML4030
Ok does it require qualcomm 2.0 or 3.0?
ShayneS
The Arlo Go charger is Quick Charge 2.0, but 3.0 should also work for OEM recommended charging only.
  • 6 Replies
  • 3602 Views
