Does not record on motion. Sensitivity is set for 100%.
My camera was working fine. After I changed my battery, it wouldn’t turn on. Had to remove the camera and re-add. Now it turns on, it will go Live and it will record manually. However, it does not record on movement now. Sensitivity is set for 100%. How do I get this to start taking videos on motion?
First check the mode you are using, and make sure it still has a rule for the camera. https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Note that you don't set the motion sensitivity in the motion detection test - you have to set it in the rule(s) for the camera.
Modes et règles
