Can I reboot Arlo Go through the app?
I am looking at an Arlo Go to monitor my vacation cabin.
I am worried about it locking up and needing rebooted as it is 12 hours away.
I see that I can reboot it in the app. Is this correct?
If this soft reset doesn't fix the problem can I remove the battery from the camera and just run it off of the AC wall adapter? Then I could put it on a 24 hour timer and reboot it once daily. If I did this would it automatically reconnect to the cell network?
Yes, that should work fine.
Modes et règles
