  • 1 Reply
  • 1372 Views
littleboss
I am looking at an Arlo Go to monitor my vacation cabin.
I am worried about it locking up and needing rebooted as it is 12 hours away.
I see that I can reboot it in the app. Is this correct?
If this soft reset doesn't fix the problem can I remove the battery from the camera and just run it off of the AC wall adapter? Then I could put it on a 24 hour timer and reboot it once daily. If I did this would it automatically reconnect to the cell network?
Yes, that should work fine.
  • 1 Reply
  • 1373 Views
