  • 1 Reply
  • 1299 Views
Txc500
Can I get replacement plugs for the charging ports? Or does anyone have a workaround to protect it from damage / moisture?
You can try using the Contact Support link at the bottom here but I doubt they can help. Surely there's some weatherproof tape that could be carefully placed over the connector (I'm thinking a rubber-based tape).
  • 1 Reply
  • 1300 Views
