I have 5 Arlo go cameras and one of them often gives the message that I need to change the battery even though I have just put in a fully charged battery. I have tried putting the battery in another camera to check it and in that camera it registers as fully charged. Any help would be appreciated.
Message 1 of 3
1,927
You can try removing and reconnecting the camera but if that fails it sounds like a faulty camera. Use the Contact Support link at the bottom here to see if they have solutions.
Message 2 of 3
1,916
Message 2 of 3
1,917
Thank you for your reply. Tried disconnecting and did a factory reset on it. I'll see how it goes now. Kind regards
Ann
Ann
Message 3 of 3
1,875
Modes et règles
