Has anyone every had a problem with water ingress into an ARLO GO camera? I bought this camera 4 months ago and the camera stopped working. I tried everything from making sure the battery is fine, that it is charging etc....
Eventually I opened it up and have found that water has entered the camera from the button at the top damaging the first later pcb near the IR diodes.
I wish to contact ARLO support by email to discuss it with them but cannot find an email anywhere. Can anyone assist?
Thanks.
kdcasa
MALTA
5 REPLIES 5
The chat doesnt work. I remain stuck on a blank screen.
Did you try the phone selection?
If its just a few months old maybe you can take it back to the retailer ? I buy most of my stuff off Amazon these days, they are so efficient with returns.
cheers
bogie
bogie
Yes thanks, I got it from Amazon.
I will try.
Modes et règles
