Just had my second Arlo Go vandalized. Anyone have a recommendation for a protective cover? Was thinking a metal basket would be good but not sure if that will block too much camera access. There are a few plastic dome styles but that would block out the sound. Any advice greatly appreciated.
I would go for the metal baskets since they won't block the IR needed for motion detection and would minimally (depending on the pitch between the wires) affect night vision without reflections. Plastic domes would severely affect both.
Modes et règles
