Arlo Go motion detection triggered by audio?
  • 5 Replies
  • 5652 Views
Kaiju
 Hi. I have one camera pointing at the front door. Obviously if that door opens, Arlo will tell me. But I was told that Arlo can also be set to alert me if there is simply sound outside the door where the camera can't see it. Is that correct? I'm not so sure. I appreciate your help.
Scott2ya
Luminary
Luminary
Yes, just like Arlo can record/notify/sound alarm or trigger another device if motion is sensed, it can also do the same if audio is sensed. Just go into your Mode and make sure there is a check mark next to detects audio.
5 REPLIES 5
Scott2ya
Luminary
Luminary
brh
Correct, but through a door, the sound would have to be pretty loud, like a car door being slammed shut, a dog barking, etc..
Brian
Kaiju
Thanks. I wondered if my loud-talking neighbor whose front door is about six feet away would trigger it. They have packages delivered daily and let them sit in front of their door until late at night-- and they've started to be stolen. Their fault for continuing to leave bait there, but I wondered if Arlo might help keep an eye on that too.
brh
He might. but the package delivery probably wouldn't. If you knew he was away from home you could detect someone coming to the door by placing a motion detector close by and get a notification if someone came close to the doors. Then let that trigger the Arlo to start recording. That is what ai did. But to defeat the delay I also put a motion sensor on either side of my door about 8 feet away to detect someone approaching my porch and start the camera recording earlier. Don't know if you can do that being that close together.
Brian
Kaiju
Thanks. Good ideas. It just feels odd to have this security inside but someone could be outside mere feet away stealing things.
  • 5 Replies
  • 5653 Views
