Arlo Go Distance of Recording and motion detection
I want to use Arlo Go for warehouse construction management.
If I install an Arlo Go at 25-40 feet...
Will it record automatically on the most sensitive setting or will the people be too far away? The people could be 30-200 feet away.
If I use live view and record manually from live view with the video be clear to see construction progress when items are 200 feet away? I'm not trying to identify faces, just see the racks being built.
Are there any long distance recordings from an Arlo camera that I can see?
Remember that the Go ( and other Arlo cameras ) are mostly designed with wide angle view.... due to this they are more suited to be 'activity' type cameras ; in that you can see what happens at a distance but not id people.
The recording, IMO, will not be triggered at long distances tho you can manually view and record at any time. Most people are picked up at less than 30ft
I'll attach some Q and Arlo Pro camera pictures showing distance , they will be similar to the GO as far as range.
200ft may be a push for much tho...will you see a car, yes... you decide
Front curb is aprox 75ft, opposide curb 105ft, house 175ft
Arlo Pro ; 720 rez
Arlo Q ( thru glass window ) ; 1080 rez
Modes et règles
