  • 11 Replies
  • 3286 Views
  • 5 In Conversation
Armydad
I have seven cameras from the Go to the essential and they all stopped recording at night. I am very familiar with the settings menu and the operations of the dashboard. Would my subscription have anything to do with it. They record during the day. All camers started 6/20 22 not recording at night. They record during the day. You can view cameras at night just not record. I would think it was a bad bad camera if i only had one but all 7. How do I see what plan I have? Your help with this would be greatly appreciated and our animals would appreciate it as well.
11 REPLIES 11
Are you saying you cannot make a manual recording while livestreaming at night?  Or just that you aren't getting any motion detection?
You go into the subscription area of the app.  You should see the subscription(s) there.  Clicking on "manage cameras" will show you what cameras are subscribed.
Armydad
ankyou for replying. I normally arm devices at night to record to motion and they all stop showing any recordings at night. I will check and see if i can record manually at night and let you know
Armydad,
In addition to the livestreaming/manual recording test, have you tried walking in front of the cameras at night while Armed to test to see if they are detecting motion?
sweetrats
I am having the exact same problem with my Arlo Essential. It just stopped recording anything at night. I too, familiar with the settings and have it set to ARMED, with no schedule. This started happening about the same time as the OP's did. I have tried many things to fix this, with no luck.
Any solutions would be appreciated.
Try something that seemed to help me - disable the camera(s) in Smart Notifications. Even though I had everything selected, including All Other Motion, disabling Smart on those cameras gave me more nighttime recordings.
No guarantee...
sweetrats
I'll give it a try. Although, I do like to know when my camera is seeing things. Let's see if this helps.
I'm not saying to disable notifications, just Smart's interpretations.
sweetrats
So, sadly, the "smart" notifications are the only notifications option I have. I did try turning them off and yes, my Arlo Essential did record at night. But, obviously no alert.  This seems like a flaw in the software. And, to be fair, it was working fine up until June, much like the OP's.
Thank you for the suggestion, though. If you have any more thoughts, I'd be happy to try them.
You could going into setting->smart notifications and drag the camera to "inactive".  Then you should get motion notifications.
sweetrats
I'll try that. Thanks.
That's actually what I meant. Disabling Smart notifications but not PNs is the workaround.
  • 11 Replies
  • 3287 Views
  • 5 In Conversation
