This is my second try at the arlo go. I do have this on a woodline but it constantly stays in black amd white . I will view live feed in black and white( like its in night mode) and when i stop the feed and the last screen shot is saved on my screen its saved in color! Ive tried everything this sucks! Help!
5 REPLIES 5
Pull the battery pack to reset the camera then replace...if if continues , contact Netgear Support
Done both already!
Its great as soon as i pause the feed it goes to color so i know there is enough light and its working. It just sucks verizon only says pull battery and netgear keeps sending me to verizon.
Sarrahbrianne,
It sounds like there isn't enough light where the camera is located if it keeps switching to black and white. Consider relocating the camera (to test) to a well lit environment to make sure the camera is working correctly. Does it stream in color?
It streams off and on in color there is good light... the second the video recording is done and it stops the feed w the play button in cenyer of screen its totally in bright color .. makes no sense!
Modes et règles
